Found on eBay Listings
farmerchris
southeast kansas
chris
put last three post in wrong section,have put them in the Craigslist section,could a mod delete last three post,thanks
cedens
Oklahoma
Cliff
305 4bbl
Lol thanks for that find Chris, i rarely check CL! but it was on the SEK Used Manstuff Group on Facebook
farmerchris
southeast kansas
chris
thanks i have to check that site out,been watching another one over on the Missouri side,big bens garage,start out with good tires and axles,now a lot of junk,lol
cedens
Oklahoma
Cliff
305 4bbl
mechanically i'm good, i just need a good 81+ dash pad wich i think i found and probably a RH door skin, the other rust holes can be fixed properly with metal fill or pached in, i may look for a bed half if its bad enough once i blast the old paint off. just have to find a dual tank bed, which shouldn't be hard.
This is from the newly popular facebook classified groups so Can't post a link but if someone in the SE KS area wants a project
1981 Chevy 3/4 ton truck 4wd
4 speed granny low transmission
350 engine
This truck has a knock in the engine, not sure what it is but it does start up. Engine will probably need rebuilt or replaced. 4 wheel drive works
$800
Guy says it has factory air too, i would consider as a donor parts truck had it been a half..... or Evil Grin make my own heavy half?
Ohhhhhh ****. I need that truck !!! $800 is a good price too. Set up for manual trans? I have a trans that will bolt right in it and I have a good crate motor for it. DAMMIT !!! I'd sell my 85 K1500 less the motor to buy that. I'd need the motor for this truck. Someone buy my K10 less motor for $800. 95% rust free, newly rebuilt Th350 with adapter for 700r4 swap, 3.73 gears and 4x4 works. AC is all there too and been converted to R134. Just needs freon as far as I know.
I'd put my A833 and the crate motor that's in the 85 in this truck. KS isn't that far from OK.
cedens
Oklahoma
Cliff
305 4bbl
You could be up there in about 4 hours, it has factory air with a dead compressor, but i do happen to have a shop manual that details a rebuild of those if you don't buy a new one.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
http://austin.craigslist.org/cto/3996803749.html
Driver4r
Nebraska
Trevor
k10,c20
John81287
Mchenry,IL
V20
Mother of pearl that truck is gorgeous!
smorris
