Ford NP208 Interchange / 27 Spline Output Shaft Th400
MadOgre
NA
NA
NA
NA
NA
Well I guess I'll get rid of the truck soon if I can't find even a matching trans/tcase I can afford
Looked everywhere and called every junkyard around, they either don't call back or are idiots and want 500$ for a tcase
I'm wore out from class and work and need a vehicle I don't have to share, I don't know if I can go another two months without one with the gf gettin a new job and classes changing
I'm in a hole and my ladder was stolen...
Why exactly do you need a T-case? What's wrong with the old one? Can you rebuild the old one?
MadOgre
NA
NA
NA
NA
NA
Oh ya I wasn't sure if that was you or not that had the busted case.
firebane
Calgary, AB
Curtis
Just how busted is this case? Are we talking like split in half or just a big chunk missing out of it?
firebane
Calgary, AB
Curtis
that size of hole depending on where it is could easily be repaired! post a picture
MadOgre
NA
NA
NA
NA
NA
Yea
And they are unicorns at this points
Well at least you still have the proper input gear from it. So if you find any right hand drop 208 you could open it up and swap input gears if need be. Just would need to put new seals in.
Heck the full rebuild kit, bearings and seals is like $125 so it might be worth going through the whole thing especially seeing as you have 2 spares for parts
Usually the shift fork pads wear out and then the thing starts acting up. So its always good to at the very least put new shifter pads in it.
silverscottsk10
trafalgar indiana
mike
That was my plan with the second one I got, but the inside of that where the input shaft goes is no good due to what looks like a burnt bearing that he kept running anyway
MadOgre
NA
NA
NA
NA
NA
Where is Trafalgar ?
silverscottsk10
trafalgar indiana
mike
Bout 45 minutes straight south of Indianapolis
I hope to have time to run to the pic a part this weekend while I'm back home and see if there is one there
MadOgre
NA
NA
NA
NA
NA
Its too bad every one is so far apart otherwise I could hook you up. I know where there's a few kicking around.
silverscottsk10
trafalgar indiana
mike
Holy sh!t
A quote for 80 pounds on a pallet for overnight is 600$ just from home to my apartment 4 hours away with an estimated value of 200$
Eff that
I'll have to ask tomorrow at work what it would cost
kobedemello
