Flowmaster 40 Series...
8T6K5
AZ
L98 350 TPI
EDIT: Title should read 40 Series...
Im considering a 40 Series...not sure if it might be too loud.....have a Magnaflow now, unsure what model and could use a bit more growll...
This thread isnt a Flowmaster vs. Brand XX discussion either, so if you run-have ran a Flowmaster on your Square, which one did you use....how was teh sound...
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Heard a lot about drone at certain RPMs, just get the 10 and let er scream.
fish on
Harrington, De
Phil
V20
I had 40 series on my 1998 sierra and she had a nice tone but at highway speeds it was loud in the cab. I went with dynomat and it worked great. If you want that classic flowmaster sound they are it!
Stroked
Beloit, Kansas
Jared
Flowmaster 10 Series...
I had a 40 series on my '90 K1500(350) and it was too quiet. Had an ok tone to it but it was higher pitched. No deep rumble at all.
Sent from my iPhone 4s using Tapatalk
It varies a lot. Tubing size, headers, cid, tubing length, cam, type of cat convertor... it all makes a difference. Usually, I think a 40 series does a nice job of sounding good and loud, without being obnoxious.
MrMarty51
Eastern Montana
Martin
I like "Straight Pipes".
Thats all:hidesbehindsofa::happy175:
I had a 40 on my '89 K1500/350 behind a y pipe and cat dumping out 2 90 degree dual 2" outlets in front of the pass side wheel under the front of the bed. Nice and bearable tone at idle, but when you romped on it it would make the yuppie at the light in the next lane spill his cappacino he he.... :D
I have 40 series on my square and love it!! I have a vid of the sound in my build thread but I'll repost here in a little bit :)
83swb
CT
Hunter
83'
350/th350
Have dual 2.5 44's. Definitely not as loud as they are claimed to be.
I have a 97 4.6 F150 (I know) that I'm running all four factory cats with a SI/DO 10 series, and it's louder than the square.
Loud pipes save lives :headbang:
MrMarty51
Eastern Montana
Martin
I`m running the cat. on Mine,single exhaust,with three inch in,three inch out,a length of pipe then a torpedo glass pack with three inch out of that,out behind the hind tire.Sounds real nice too.
I have been thinking of removint the cat,running duals,no mufflers and 1-7/8ths inch pipe,straight out behind the bumper.
Them babys sound sweet,not too loud,until,well when tromping on the throttle them babys really talk and the smaller diameter piping gives um a real nice tone.
Driver4r
Nebraska
Trevor
k10,c20
Im Running 2" duals with Glasspacks(basically resonators) And it sounds pretty good when you get on it :D . And my 355 is also pretty mild, so that helps to.
MrMarty51
Eastern Montana
Martin
Thats a mighty sweet sound.
The 1-7/8ths pipes gives them a bit of a "Crisp" tone.does`nt damage performance,I do`nt think.
dabsRus420
