fitech install om 77 c10
77c102door
Newark
Harjeet
update. car is fixed. the timing was off. according to my friend, the truck was 12 degrees retarted. he advanced it to 2 degrees and its running perfect. heres the picture of how much it was off, u can see the vacuum port mark on the valve cover, prior of taking out the distributor. I have to drive the truck at least 300 miles to let the computer learn the parameters. but this kit is awesome
R8rPhan
California
Mark
1973 (1979?)
C10 long bed (Frankenstein truck)
What I'm thinking, is if the fuel sender is still in that 88 donor truck's tank, I'm thinking that it is a FI pump as well...
If so, I can grab that and then use it to make a surge tank/fuel commander.. Just a matter of fabbing up a 1G tank for it, adding fittings and maybe even a couple pressure gauges...
Viola! Just saved myself 400 bucks!
R8rPhan
California
Mark
1973 (1979?)
update. car is fixed. the timing was off. according to my friend, the truck was 12 degrees retarted. he advanced it to 2 degrees and its running perfect. heres the picture of how much it was off.
Well, that would definitely make it run bad! :cheers:
77c102door
Newark
Harjeet
heres a video of the truck running. as you can see on the command center low pressure gauge is reading lower because i have roughly 4 gallons in the tank. when i fill up the tank, it would read 6-8psi.
R8rPhan
California
Mark
1973 (1979?)
But does that still cause the problem, now that you've fixed the timing?
I bet that if you got a cheap electric pump and installed it lower than the tank or about level with the bottom, that problem would disappear..
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Awesome man, glad you figured it out. 2 degrees BTDC doesn't sound like much timing though. Guess it just depends on your cam's profile.
77c102door
Newark
Harjeet
with the dieseling problems and everything else, yes the timing fix the problem. ur probably right about a electric pump or upgrade my mechanical pump to a higher volume pump
77c102door
Newark
Harjeet
right now my truck is all stock except for the fitech so it has a stock spec cam. so 2 is set from factory. i can advance it more but for right now im good as it sits
74 Shortbed
Man.. Both of those items are half again the price of the Fuel Commander..
Hell, I'd never buy one of them I'd just make one, and I sure wouldn't use floats they do stick sooner or later, had one bad experience with them that was enough, after that I used a return line no more failures for 20+yrs..
R8rPhan
California
Mark
1973 (1979?)
What do you mean by floats? In the surge tank?
I think I'm following you.. Just using a return line and letting the can completely fill up and then run back into the supply tank as opposed to using a float in the can to shut off the input flow from the low pressure pump?
I think this answers my question about how many ports I need on the senders I need to order..
Best scenario is a three port sender on each tank, a 6 port valve that switches both the supply and return line, and a surge tank in the engine compartment with a return line back to the 6 port valve..
And I'm assuming that a pump/sender from a late model GM truck would be fine in the surge tank to supply pressure to the EFI?
74 Shortbed
Yeah, look at the pic you can see the float, at that level just put a fitting on the side for a line going back to the tank and that's the highest the tank will fill. Any EFI submersible pump will work. For fittings it's whatever you need for the unit you get, you need in/out and whatever returns the system has, simple deal.. I am a very strong believer in the K.I.S.S. method, mainly because I'm a *******.. :D
R8rPhan
California
Mark
1973 (1979?)
Excellent! I think I just saved a whole bunch of money on my EFI!
"50 minutes can save you 50% on your fuel issuance"
:cheers:
bluex
Spartanburg SC
C15
You guys are really over complicating the fuel system side, an 87 tank an sender with a 96 fuel pump seems alot easier to do, to me anyway.....
Sent from my SM-N920V using Tapatalk
MKR2011
