Factory Sway Bar Options
you can use the blazer S10 2 door Z52 rear SB is fit right between th C10 rail and coast a dime in Junk U pull :)
That's good to know, I have a couple of those already.
Magna86
VA Beach
Magna86
Chevy 350
Well I struck out at pick in pull. All 4 door blazers. Now to check other yards
Did you grab one to try anyway? I'm betting the rear facing bar would work well too. Plus they work well with 90's Jeep front sway bar links (the offset ones) to make up for differences in frame width.
Raider L
Shreveport, LA
William
@Magna86
I got my front one, at a wrecking yard off a C20 or a 3/4 ton or something like that. It bolted right in. It was to long ago so I have no idea what they are going for these days, but cheaper than a after market one that's for sure.
Raider L
Shreveport, LA
William
@Bennyt,
Benny, they wanted it powder coated with new bolts and poly bushings, for $10. Then they would have been lined up down the street. Or better...free!
Bennyt
Surprise
Ben
@Bennyt,
You're not too far off; on some of the parts I've sold lately, I've gotten some pretty lowball offers. They show up in a new $65k truck, buying parts for a $50k build and then offer me $5 when I'm only asking $10 for a hundred dollar part.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
A lot of 80's C30 crew cabs had a rear sway bar.
That's what I said. The Camper Specials all had them. Big Blue (<<<) has one. It really doesn't need it though, with a Dana 70 and duals it's sticks.
Magna86
VA Beach
Magna86
Chevy 350
No I didn't. The 4 door bar would probably work as the 2 door but need to find different endlink as the ends are straight to bolt thru unlike the 2 door which are flat.
Raider L
Shreveport, LA
William
The problem is with a Surburban has the spring "u" bolt nuts on the bottom, they're flipped over from like my year C10. They have an ear off the side of the bottom mounting plate for the sway bar attachment. Also the bar of the burb is only like 3/4" or so. I don't see how that controls the sway on such a heavy vehicle. In my mind I want at least a 1" back there. When I get my rear sway bar, I've already got it picked out it's 1". My front bar is a 1 1/16". I want my truck flat in turns and I've got the perfect place to test it out. There's an exit on interstate that is a double back turn of 370 degree turn. In other words it turns off interstate, goes uphill then turns back again, it's real messed up of a turn where you don't turn the steering wheel once and you make the circle. Noooo, mid way through the turn it turns back again even sharper then once on the overpass above it then it straightens out.
When my truck was newly rebuilt with all fresh poly in the suspension I made that turn at 60 mph. The tires were squalling their brains out. I felt I could go faster but the truck was twisted in half as it was, and I felt I was about to come off the road so I backed off. I want to take that turn at 70 or as fast as it will go maybe 75! It'll be like being in a sling shot when I get on the overpass above.
ExtraZ
