Factory GM Guages ADD tach?
Best truck design
Lexington KY
Chas
Sierra C2500
Has anybody here done the Factory Tachometer ADD to the GM cluster offered through LMC?
You replace the huge fuel gauge with a factory looking tach and place the fuel gauge over in the small gauge clusters.( in my case replace the huge BRAKE light with a fuel gauge.
In order to do this change you need a tach, wiring for the tach and the Mylar wiring schematic for the back of the gauge cluster?
Thought comments?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
It can be done, but it's a pain.
I do plan on adding a factory tach and fuel gauge to my daughter's '73 Cheyenne when we get a chance. I have one that works, just need to get the wiring for it. I will be adding it to the cluster but just running the fuel gauge wires to a custom connector separate from the mail cluster.
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
I did the conversion a couple of years ago on my '91. It's not exactly the same as a '73 but very simular. All wiring was included or ordered separately, can't remember. What i can remember is that it was not very hard to do. I did find some pics.
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
I did had to install an emc filter afterwards, the needle of the tach was too shaky. Found that on ebay.
Best truck design
Lexington KY
Chas
Sierra C2500
Thanks I love the look of the factory gauges and think GM was at their peak for truck design back in the 70's. IMO this is the best looking truck that was made (dash included).
I will be doing the conversion at some point.
Best truck design
Lexington KY
Chas
Sierra C2500
Did you get your gauges from LMC?
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
yes i did.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Exactly what I need to do! Couple questions.
Did you have to cut the hole for the tach connectors?
What kind of connections were on the fuel gauge?
Did you have to modify the bottom left hole any for the fuel gauge to fit since that's normal a blank with just battery indicator?
Did you do anything with the battery light?
Sent from my SM-G950U using Tapatalk
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
5k rpm meh not enough lol
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
Yes, see pic 2 in post #3.
I can't remember having problems with the fuel gage. I proably just connected the 2 wires from the old big gage to he new small gage.
yes, a little, see same pic.
Well here i went wrong at first. I first connected the light to the instrument cluster lighting to use it for my new litlle fuel gauge, but every time i put on my lights the alternator stopped charging the battery, you know battery light on, no charging. So i simply disconnected it. New litlle fuel gauge is in a kind of dark place at night but it's not that i have to look at it much. If the battery was not charging i would see that on my voltage gauge.
ben_swager
