Exhaust routing? What did you do?
WillSquared
Arkansas
Will
Im starting to think about the exhaust on my truck. It's currently the stock manifolds to a y pipe and single in/single out muffler run out the drivers side. I'm planning to go with full length headers run to a dual in/dual out 50 flowmaster and I haven't decided on exit location or just turn downs. What are you running and what made you decide on your particular setup? And of course, post pics if you've got em!
Sent from my iPad using Tapatalk
Skweegle89
Oklahoma
Im running duels off factory manifolds with Thrush mufflers. They sound alright, but the PO dumped them right on top of the rear end for some reason. I personally don't like them turned down. They stir up too much dust and I don't like the echo off the pavement.
Boonie
El Dorado, KS
Brent
im using a turn down off a magnaflow. have this setup on two different trucks. just don't like the look of a tailpipe
Konas new ride
Alberta
Gerald
I prefer out behind the rear wheel.. I dont care for the heat on the ground from a turn down when im in the bush..
hirschdalechevy
norcal
rich
k-30
I personally like the sound bouncing off the pavement way better than free air set up. I always go over the back axle and 45 the tips to the side and 45 them out the back , (sounds good , looks good). On my blazer it was a little harder because of the tank, ( had to change the angle's a bit).
77 K20
Montana
K20 5" lift
HT383 fuel injected
I have the Thrush welded mufflers and then have them dumped right afterward. The exhaust is nice and simple- almost a straight shot back from the ram horn manifolds.
When off roading I do not have to worry about hitting it on anything. It can kick up some dust if it is really dusty out- but it isn't like I'm afraid of getting the truck dirty.
picture.php
picture.php
77 K20
Montana
K20 5" lift
HT383 fuel injected
hirschdalechevy Do you have spacers on your wheels? Just noticed I can see damn near your whole rear brake drum on that!
highdesertrange
kalifornia
mike
k30
14 bolt dually axle, with a single wheel. highdesertranger
hirschdalechevy
norcal
rich
k-30
Nope , those are 15x14 bart wheels , 3 1/2 back space , 8 lug , Its all in the wheel. And its not a dually axle.
hirschdalechevy
norcal
rich
k-30
Here is a pic of my wheels , they are that back space so I can clear the brakes with a 8 lug axle's and still run 15's
I just got done mounting these babies by hand , not fun.
jeffro308
Jeff
1-Tonified
HT383/4L80E/Black-Box/NP205/D60/14BFF
You gotta get a good tire shovel.
kaydenfeathers
