Exhaust pipe bracket
Rich77
SE Wisconsin
Rich
C10 Scottsdale
Hello All,
Regarding the bracket that bolts to the inside of the frame-
For those of you who have gone from single to dual exhaust or have needed to replace an exhaust bracket, what have you used or where have you bought one?
I can’t find new oem style brackets.
I thought that maybe I would fab some 3/16” thick triangle shaped brackets.
But if someone already makes a replacement, I would probably just buy that.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Are you needing the driver’s side or passenger’s side brackets? I may still have a set from a factory dual exhaust pickup
Rich77
SE Wisconsin
Rich
C10 Scottsdale
I actually need both. My truck was single pipe but the brackets were rotted.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I used these hangers from Summit if you’re willing to weld, I couldn’t find any good pictures of how the rear mounts are bolted up.
Rich77
SE Wisconsin
Rich
C10 Scottsdale
Thank you!
Rich77
SE Wisconsin
Rich
C10 Scottsdale
Instead of welding in brackets/hangers, I decided to run an aluminum angle from one side to the other and bolt my hangers to that. I’ll trim the hangers down.
Does anyone see an issue with that?
I have a similar bracket setup at the front of my mufflers but used HD angle iron with pre-punched holes. It’s not that attractive, but it works.
seanhatesregister
