Exhaust Leak
83kid
Massachusettes
If i hear a tick ill take them out and throw a little locktite on them to hold em in there, gonna leave them for now since they seem fine
Skweegle89
Oklahoma
I don't know that I would do that. If you do you might not get them back out without breaking them off. I have manifold studs that don't have any locktite on them that are broke off and idk how im going to get them out.
83kid
Massachusettes
I always thought locktite didnt actually sieze up the block ,you could break it loose, just it wouldnt spin loose. When ive installed new reeds in some marine engines they actually say to use loctite in some cases to hold the screws in there so they dont spin out ,and its still easy to unscrew the screws
1low4x4
Nick
Like i said, buy stage 8 locking fasteners and crushable aluminum gaskets and never touch it again.
Header/manifold bolts/studs are easy enough to break by themselves...locktite can only hurt
73n707
Petaluma, CA
Robby
Custom Deluxe mix
Do you hear it at idle?
If so, start engine and use a long piece of rubber hose/tubing, probably 3/8" or bigger.
Hold one end to your ear, and move the other end around the headers where they attach to the block, and where the collector bolts up.
You will hear it loud and clear when the other end of the hose is at the magic leaky spot.
The rube is magic!
Fluffyfreak505
