ESC module
martingmc86
california
martin
gmc sierra 1500
v8 5.0
Hey guys, I just did a EFI conversion to my truck, but I’m still having issues with it. I had my EGR and my oxygen sensor removed but I got it back installed and my truck is still running really bad. I think it might be my ESC module just because I installed a new spark plugs and my spark plugs get really bad on carbon buildup. I clean them. The truck runs great the spark plugs get back to Carbon buildup and it runs bad again my distributor is brand new and it is in HEI. connected to the esc module my ESC so is the only thing I have not replaced is my ESC. Does someone know where I can find a new ESC or remanufactured ESC?
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
If you did an efi conversion Why would you be using the esc distributor? That's probably the problem.
Get a regular hei distributor and adjust it. That should solve the problem unless I'm missing something.
I'm guessing you put one of those new electric carburetors ? The ESC distributor only works when you're using it with everything. I don't know allot about ESC but someone here does that will hopefully chime in.
squaredeal91
Greg bush
1991 SB
Here's an example. Only $50
There pretty good but the modules in them are cheap but can replaced with high quality. I've bought a few like this over the years.
Spork
