- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
John sorry, but I'm a little unclear on the location you suggested. Do these are need to connect at the same location. I wouldn't think so, but I may be wrong, also what do you mean between the rubber mounts.
He doesn't mean to hook between the rubber mounts, He's saying like, BETWEEN you and I, I'd hook up as many grounds as possible. Or as, BETWEEN This Heat, and this Humidity outside, it's miserable.
Your motor is mounted to the frame with rubber mounts that DO NOT conduct a ground, so you need to take chassis grounds to the motor, since grounds don't come naturally. Even the trans is mounted on a rubber mount.
