Engine troubles
Rusty Nail
Rusty
350sbc
^ true...those numbers indicate a measurement of length, ribs, and pulleys, etc.
uprising
Germany
Charly
Hi guys!
I got it :)
It was a combination of wrong calibrated carb and gaspump! I fixed it and now the engines runs pretty nice.
Now i have an other problem with the trans. (TH350) I know that the old engines and trans can sweat a little bit but my trans drips!!
There is a puddle under the car. I will upload some pics. I hope you can see it. Is there a way to fix it without removing the whole trans?
There is a vent on the top of the transmission. Should i remove the cover?
And how can i identify which oilfilter is installed in the transmission? The square or the "round"?
And one other thing. Can some inform the admin or the endboss off the side that i´m not able to enter the homepage from germany. I get following error "Error 1020 Access Denied" from Cloudflare. There is a problem in the firewall... In the past it was working.
75gmck25
Northern Virginia
Bruce
Its probably just the gasket on the pan that's leaking, so plan to replace it. Trans fluid is thin and seems to find every space to leak. As far as filters, I believe your '73 TH 350 probably had a square filter with simple screen However, I think you can also use the newer Dacron filter and its a better filter medium than the older square filter.
On the transmission, also look for the small metal vacuum line that runs from the engine, and the short piece of rubber hose that connects it to the transmission modulator. This hose can get soaked with leaking trans fluid and start to fall apart. You want the modulator working properly and connected to engine vacuum because this is what controls the shift points of the TH350.
Since you have been working on the carburetor you want to also check your transmission kickdown linkage at the engine. The kickdown cable is held in the bracket by a square plastic retainer. On the back of the retainer is a small plastic sliding piece that moves up and down. To adjust the cable you pull the sliding piece up (it might take a screwdriver or pliers to get it loose), move the carburetor throttle to full travel (max throttle), and slide the plastic piece back down. This will ensure the transmission kicks down a gear when you accelerate. This article has some good pictures of the kickdown cable adjustment (its the cable to the back, right in the first picture). http://67-72chevytrucks.com/vboard/showthread.php?t=217076 In the 2nd picture you can just barely see how the retainer behind the metal bracket has two parts. The part immediately behind the bracket is what slides up.
Bruce
uprising
Germany
Charly
Hey Bruce,
thanks for your fast answer. The gasket is a new one. If you check the second picture, there is a smaller screw on the left side of the pan. There are the drops... So my fear was/is that there is a leak between the transmission/engine. Do you have a picture of the vacuum line? can i reach it easily?
Kick-down is working pretty good! Also the shifts are good! There is only one weard thing.. I go into "R" and it takes 2-3seconds before i can drive reverse. Before it feels like i´m in "N".
Pascal
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
@uprising
Front of the transmission down the dust cover is usually input shaft seal.
Pull the transmission, then torque converter, replace seal. Pain to get to butt a simple replace.
uprising
Germany
Charly
holy... That sounds like pretty bad job. So i have to remove the whole transmission or is there a way to keep it inside?
Snoots
Roger
Jimmy Sierra
350 w/203
Easier to remove the tranny.
uprising
Germany
Charly
oh man... ok! Got it! Does someone have a kind of "How to" for the removale? Which sizes does the screws have? I don´t have a lot of imperial tools. So i have to buy some for the remove. Which gaskets to i need? Is there is list or a kit with all needed parts?
uprising
Germany
Charly
Hey guys,
has nobody any informations about the sizes of the screws? Any tipps and/or infos for the remove? Can you use the transmittion gasket kit or do i need another or something additional? Is there something special because of the 4x4?
And i have a weird handling:
If i switch into „D“ it takes 2-3s before the gear is „in“ and i can drive. Same to „R“! What is it????
And who is the responsible for the forum? The access denied error drives me crazy...
From netherland it is also working!
ExtraZ
