- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
Yes the rear is that deep. It’s actually behind the engine.Couple more on the left rear side of the block. I only ask about these because the guy that built the motor stripped it to hot tank it, so not sure if there is anything missing, like a plug, etc. Also, many times bosses this close to an oil filter will work for an oil pressure sensor, etc.
These holes are deep - I can put a longer screwdriver all the way in the back one.
THX
Yes the rear is that deep. It’s actually behind the engine.You must be registered for see images attachYou must be registered for see images attach
The factory spot is behind the intake next to distributor. I pretty sure it’s a 1/8” pipe thread.Where is a good tap for an oil pressure sender? Any idea what the thread is?
THX fellas.
Thanks Lug! Unsure at this point what will fit where until I get the FI intake on.The factory spot is behind the intake next to distributor. I pretty sure it’s a 1/8” pipe thread.You must be registered for see images attach
Almost all the fuel injection stuff also take oil pressure from there. There is often an oil pressure switch that is threaded into the small plugged port right above the oil filter and down to the left of the hole you had the screwdriver shoved into. That location doesn't get as good of a pressure reading, but is good enough for a switch. They use the switch for choke and fuel pump power on fuel injected engines. This allows the engine to keep running even if the fuel pump relay dies while driving.Thanks Lug! Unsure at this point what will fit where until I get the FI intake on.
I think auroragirl was making fun of all the bolt-ons (like a dipstick tube) that are labeled as performance parts.
Just search a few other forums (Mustang, Camaro, BMW, etc.) for postings on painting calipers and you will realize how many guys think it really increases the “cool factor” to have painted calipers that show through their fancy wheels. BMW even offers different colors for your calipers as a factory option.
