Engine swap questions
87silveradok20
Ohio
Levi
Silverado k20
In 87 they went to TBI, TBI heads have the center bolts at a different angle than the earlier heads. I believe all heads with center bolt valve covers have the different angle. You can take a die grinder and clearance it out and the early style intake will fit the later style heads.
And the later engines don’t have a mechanical fuel pump provision correct?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
It's kind of hit or miss on that, I've never seen a TBI engine without the mech pump hole and everything, and I've never seen a Vortec 5.7 with it. But I've been told by others they have seen both.
jamba
Ruhtinansalmi, Finland
Jarmo
Blazer K5 Silverado
6,2 Diesel
Thanks, mate :)
jlyon1006
