Engine swap questions
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
A set of injectors for a 12v aren’t actually all that bad. If I could find an 8.1 It would be sweet but they are hard to come by
They are incredibly easy to come by, especially for the price of some of this other stuff people are throwing around lol. I only paid 4500 for my entire truck lol.
Like I said, about 1500 bucks,
87silveradok20
Ohio
Levi
Silverado k20
What website is that?
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
I was looking for a small block to go in my 80 c10 s/b . was on c/l and found a 1996 2500 5.7 with a 4l80e for $500 I went and got it pulled the eng trans ecm and harness my buddy striped the int and brake parts off and I halled it to the scrap yard and got $180 out of it there so I am in it for $380 look for wrecked trucks for the parts you want
87silveradok20
Ohio
Levi
Silverado k20
Trust me I watch Craigslist like a hawk.
87silveradok20
Ohio
Levi
Silverado k20
Well I think you guys have talked me into an 8.1/4l80 combo. I’ve done some research and this seems to be the best option for me.
Jrgunn5150
Ionia Mi
J.R.
6.slow
In case it wasn't clear, the dyno sheet above is from my truck, tune only, I daily the thing, it's great.
roadracerga
ga
charles
c30
Cummins is probably cheaper then a good crate engine and FI. And well it's a Cummins is why....but I'd mate it to a 4L80 not a Dodge transmission.
I have yet to see a thread exactly like this so I figured I’d start it. So this winter I am going to swap the motor in my truck. The truck is an 87 k20. I’ve narrowed down what I want down to 3 options. 1) crate 350 or 383 with aftermarket efi, 2) 6.0 and 4l80, 3) Cummins with dodge overdrive trans. The truck is just a driver and will occasionally pull a trailer but not a huge one. If I go with a gas motor I will probably get 350-400 hp out of the motor. If I go Cummins I probably will leave it relatively stock and just turn it up some. I want it to have good road manners and I don’t have a huge budget to do all this. So what would you do and why.
I have engine to do Cummings swap 5.9
93 non electronic use 47RH trans will need switch to operate OD
Best part is 20-25 mpg
Benny B
Greenwood mo
Benny
5.9 cummins
I put a Cummins in my 83 with nv4500 and a np205 never added up the receipts for a reason but it’s dam fun to drive
jamba
Ruhtinansalmi, Finland
Jarmo
Blazer K5 Silverado
6,2 Diesel
Sorry to ask such a noob question..
What difference has been 350 engine near 1985? Some "crate" engines are for pre 1985, some are from 1987 on... My Blazer K5 is 1986...?
Jrgunn5150
Ionia Mi
J.R.
6.slow
In 87 they went to TBI, TBI heads have the center bolts at a different angle than the earlier heads. I believe all heads with center bolt valve covers have the different angle. You can take a die grinder and clearance it out and the early style intake will fit the later style heads.
Love Samantha
