Sgt Gus
- Aug 2, 2023
- Texas
- Mark
- R20 3/4 ton
- 454ci/7.4L
Running the truck on it's 2nd break-in.
Running between 2500-3000rpm.
Getting code 44 (lean exhaust).
I assume I need to increase fuel psi at regulator. I haven't set idle timing yet, I was going to get her broke in 1st?
I thought my Maddox gauge said 14psi at location just past fuel filter though...
She is Running hot, but in the garage with back end out, so no air other than fan and aux Running. Gets above 210.
What hits ya? Double ck psi, should I increase yet...don't worry about excessive heat going 70mph in garage?
