Rotella
rotella does not any longe have the amount of zinc and phosphoruus that flat tappet cami motors need. get Vr1 racing oil or get luca classiic and hot od or break in oil/.. or brad penn motor oil.
period.
any motor oils with the API circle certification on the label are junk and useless, for flat tappet camshaft motors.. which is most early TBI motors at least '91 and older, especially truck motors, and all the carb motors. if you want to keep from wiping cam lobes then get VR1 or hot rod or break in oil. 40 bucks a jug.. thats the best deal youre gonna find for the oil you need to have. amazon or wherever. API cert oil nowadays all has none or VERY reduced levels of zin(ZDDP) and phosphorus. flat tappet motors need both of these in high levels. and for a damned good reason.
if you dont care about your motor, mainly the cam lobes and lifters and bearings then run whatever oil you want.. i dont care, its your motor.. good luck!
Is it the T3? The oil for diesels, it has zinc. The only reason I will walk into Walmart is to buy the 5 gallon buckets of it.
Yep it's True. Rotella no longer has the extra goodies that people used to buy it for. Hasn't had for several years now. If you're looking for Zinc you have the option mentioned above, or buy an additive. My flat tappet engines do just fine with Super Tech synthetic without additives. Normally, once that cam is well broke in you shouldn't have any flat cam lobe problems.
ck4 has the same amount of zinc as cj4.I can't find any proof either way... Regarding T-4, I always thought the CK-4 rating had the zinc.
As you said, after the cam is work hardened, broken in, there's no need for zinc.
