- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
My conversion was a 4WD and it was over twenty years ago, so even if I could find them they still wouldn't help you. Sorry.
But you can probably still get away with using the diesel components. My friend used the gas components on his diesel and got away with it. You'll just end up with bigger motor mounts for a smaller engine. Win - win.
I find it odd that the squarebody got bigger mounts for the 6.2 diesel. I've got mounts from GMT 400 trucks. Big block, small block, 6.2 and 6.5 diesels all share the same bracket that bolts to the block. Not sure about the rubber isolator, but they almost have to be the same. Also interesting, those brackets are the same as 2nd gen Camaro.
