LuvNLife
- Jan 10, 2014
- Crossville, TN
- Jerry
- C10 Silverado
OK; my new to me '85 C10 is sitting in the garage inop. Here's the story:
Just bought the truck this week. Had it towed home (torrential rain) and parked it in the garage. Was out with it Thursday and let it run for about 15 minutes and burn off any moisture left. It has no choke, so had to pump it, crank 3 seconds, repeat several times and it fired, no problem. Went out today to take it for it's maiden voyage, pumped and cranked twice for 3 seconds, on the 3rd try, dead. The lights on the add-on gauge cluster light, even the key buzzer works, but as soon as you turn it to start, they go out.
New last month battery with 850cca, terminals are tight, no hot wires, no smoke. Now, the key had felt like it was in a slight bind when you would turn it to start; now, there's no bind at all. This is wilh a non-tilt column.
Thoughts on where I could start troubleshooting? If it got into impossible to find steering column parts, and thoughts on putting in an old-school push button starter button as found on old trucks?
Thanks!
Thanks!
