- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I think it means your intake gaskets may need to be serviced. its okay because that EGR port means its probbably something like @SirRobyn0 had inside his manifold lolDsitributor as far as I know is the original hei, looks like photos you sent, I take manifold appears factory, has the firing order on it. Was an egr manifold but has a block off now. Could distributor gasket cause a vacuum leak? I didn’t replace it when I had the distributor out I didn’t figure it would harm anything such as a vacuum leak. I can check the linkage I don’t recall any play though. The mixture screws are set to the best vacuum I could get, averages 18-20 at around 600 rpm idle. But if you recall I had a random vacuum leak(12 ish vacuum) and truck idled weird and off idle ran fine? I noticed that there’s oil pooling on the intake manifold. I was reading the middle bolts can have oil seep through the threads? Could that be the case? Could that be a vacuum leak?You must be registered for see images attach
Good time to improve it
also you have mechanical choke still or did you put a electric on? whats that hose doing there in pic?
and you may try a POWERBLAST plate upgrade to your carb
they are on sale. makesy our mixture more easily vaporized and then the engine can have better throttle response and take off from idle and closed throttle, common issue on edelbrocks
what CFM is that? here is 750-800, if you have less they have a product for that too but you need to find that on their products page https://thompsonperformance.com/products/pbp-ec-78
