- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
pICSI’m fine with under $100 but like standard hei distributors were like 160 and some other brands like cardone or something were upwards of $200 and this isn’t a race truck or even a traveling truck it’s just an old beater work truck that I just need to run. Also speaking of fuel pump, two or three line? How can I tell what the truck is supposed to have? It currently has a two line and the one removed appeared to be a two line. Could the truck possibly need a 3 line because it’s getting too much fuel buildup without a return?(assuming a return is the third line). The distributor I have in my cart is like 55 just a generic cheapo one. It’s description makes it out to be a ready to run unit including everything. My personal opinion the physical distributor can’t have much go wrong on it, being just a slot at bottom with a gear on it. But the weights and everything else might not be good. Also the vac advance would be questionable. But I already think my vac advance is questionable. I couldn’t suck hard enough for visible movement.
