Yes. That’s what I’m going to do. I would really appreciate it. Thank you so much.
Ok, Filler neck. You could check LMC, but as far as I know used is the only option. I had a couple guys here willing to sell me their extras so you might run a request in the wanted section.
Fill hose and vapor hose from filler neck to tank, purchase universal bulk from your favorite auto parts store.
Pollak 42-308P Fuel Selector Valve Kit, kit includes valve, pigtail, cab switch and instructions, you'll need to buy wire and follow the instructions to wire it up.
You'll need a sending unit which will vary in part # depending on if it's going on the right or the left and if the truck has a return line.
I can't seem to login to spectra at the moment, but spectra is the company we have used for both sending units, tanks and straps. You'll need to decide if you want a 20 or 16 gallon tank, or if there is some reason a 20 won't fit. You'll need to decide. Spectra is sold by O'reilly's and other companies.
The carrier can be very hard to get and I can't give you a part number. If anything hangs you up that will be it. I think I still have a spare set and can see if I can find it in my barn this weekend if you want it I'll sell it to you for what I paid for it. So it looks like I paid $159 for the carrier and it included the straps. It's new not used. You'd need to pay the shipping in addition to the $159.
You'll need bolts to bolt the carrier into the frame. You'll need anti-squeak material to go between the tank and the carrier, I just cut somethin rubber matting I had hanging around to fit.
Hopefully that helps.
