Drinking coolant
Oldrider
NC
k2500
Have you run it till hot and checked really good under the hood to see if you can find any wet spots around the radiator or hoses?
It is harder to find when hot as the coolant will dry up quickly.
highdesertrange
kalifornia
mike
k30
was it ever filled up correctly when the heater core was replaced? highdesertranger
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Check for leaky casting plugs as well.
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
To be honest I don't know I bought the car on the 16 of October. And the guy never told me.
Iowan
Iowa
Calvin
K1500
350 crate
Well found out it was a coolant line,now only if it didn't blow and I could have caught it. but hay what can you do?
75gmck25
Northern Virginia
Bruce
Also check the heater hose where it connects to the top of the intake manifold, and the upper radiator hose connection to the thermosat housing. If water seeps out around these hoses under pressure it runs onto the hot intake and just evaporates right away. You can usually stop the seepage it by just tightening up the hose clamps a little.
IIRC on some trucks there is also a mismatch of the hose sizes for the heater hose connections. I think one hose is 5/8" and one is 3/4". Many folks try to use the same hose size on both fittings and don't get a good seal. The heater hose fitting screwed into the intake is also available in either 3/4" or 5/8", and someone may have used the wrong size. If they decided to use one of the fancy chromed fittings for the heater hose or thermostat housing it is also harder to get a seal.
I would also consider replacing the overflow tank. I could never find a leak in mine, but replacing it seemed to keep the fluid level much more constant, so I think it did have seepage somewhere.
Bruce
JoeyC75
