DoubleDingo
- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
No progress on fixing this beast, but on Monday, with a little help from my wife, Crusty got the ugly side facing away from the street. I have towed many vehicles with the old tow bar I acquired after grandpa passed away. One of those you hook to the top and bottom of the old heavy steel bumpers, and run the lower hooks to the frame, tighten it all up and the vehicle will tow pretty well.
Since this was a short trip around the block, and slow speeds of 10 to 15 mph tops, I didn't tighten the attachments to the frame, just used the top and bottom bumper hooks. I had a feeling this flimsy after market bumper I got from LMC would not survive, but I really didn't care. Good thing I didn't care, because I was right, it bent.
It bent right as soon as we went off the driveway into the street. It didn't help that my wife was holding the steering wheel so the front tires couldn't track on the turns. I told her to let the wheels track, but they turned and locked, to turn them back straight. I should have just used bungie cords, but it was a learning experience for her.
Trying to make the first turn in the street so we could go straight to the next side street, the jeep was going sideways. The more I tried to turn right, the more the a$$ end went left. This has never happened. I got out and looked at the setup, yeah the bumper was bent, but the hooks were still hooked, so I checked for tightness, and tightened what was loose. Immediately upon us having to stop in the middle of the street, one guy stops southbound offering to help, and another stops northbound offering help. Knowing we didn't need a bunch of chiefs to figure it out, I told them to go ahead after thanking them for stopping.
Honestly, if they had tried to help, I think it would have just gone downhill from there.
I tried again, jeep kept going left as I turned right. I got out again, perplexed, and then saw the front tires pointing straight. I cranked the wheels to the right, started going forward in the jeep, and it tracked like it should. Until the next turn. Me not knowing why the wheels weren't tracking, I was motioning to my wife to turn the steering wheel. But she could barely see me because of the windshield being so dirty.
Got to the next turn and I again motioned for her to turn the wheel with the turn, and it tracked better. I then stopped, checked the hooks again, everything was out of whack, but we were half way through, so I just went, but told her she needs to turn the wheel when we turn.
Going into the driveway was just as bad as coming out onto the street. The jeep is going left, I am trying to turn right, and it's not going where it should.
I get out and turn the wheels as I can see the rear tires of the jeep are being turned under, if you will, because of the tremendous amount of side pressure on the tow bar transferring through the hitch. It took a few tried going forward and backward to get it to where I could finally loosen the hooks.
With Crusty facing towards the house, I can begin tearing off the damaged sheet metal, and assess more of the damage from the wreck. If everything checks out, I will replace what needs replaced, and get it running with the crappy v8 in there now. That would allow me to drive it while I do the other stuff to it, and also allow me to move it around more freely for doing other projects.
Once I start back on this I'll post the carnage as I remove stuff. It'll piss me off all over again to see it, but it needs to be done.
