Door Vent Window Ass'y Question, W Pics.
Toad455
North Texas
Kevin
Hello, I'm replacing both of my doors on my 78. I have two good donor doors that I'm sandblasting and getting ready to epoxy. In the pics with the arrows there's a metal flange that "appears" to be spot welded and broke. I was going to weld it up but my original doors (blue doors) are the same. I also noticed a screw (circled) that I never knew was there. My questions is: Is that area supposed to NOT be welded so it can slide back and forth for adjustment, then tightened after assembly with that screw? Or is there a weld that is broke? It seems like that long screw can be backed off to allow the inner and outer door shell to be spread apart for ease of removal and install of the vent window assembly, then the screw be tightened up to draw the inner and outer door shells back together to be tight against the seals. I can't believe I've never noticed this over all the years of working on these trucks. Thanks.
ali_c20
Austria
Alexander
C20, K5
I think that's the right explanation. I have this on my 74 c20 doors with a screw on both sides and had to loosen them to get the vent window out.
Toad455
North Texas
Kevin
Thank you much, that makes sense. I'll have to put the new seals on to see how far to adjust that screw before I do my final block sanding so there won't be a pooch or sag in that area. I played around with screwing it in and out and it makes a big difference.
Toad455
North Texas
Kevin
I'm glad I didn't weld up where I thought it was broke.
rtomrdle
