Does anyone recognize these?
tj43
Little Rock
TJ
V1500
I am trying to order a RetroSound radio for my 88 Suburban. Does anyone know:
(A) which retrosound bezel fits this opening; and,
(B) which Metra (or other brand) harness adapter fits these connectors?
Thanks in advance. Pics are below.
With the exception of the constant memory plug (the smaller one), the conversion connector for GM vehicles through '89 is what you need.
For the constant memory wire, you will just have to put a spade on it and plug it into the factory connector.
tj43
Little Rock
TJ
V1500
Closing the loop here, bucket was 100% correct. I ended up using an “add-a-fuse” tap on the “horn” fuse to get constant 12v power. Everything else was plug (er… solder) and play.
idahovette
Weiser Idaho
Perry
K20-K10
I thought he was once, but then figured out I was wrong and he was right???...............
Lol, I'm definitely wrong sometimes.
I put the radio in my '88 Suburban in '06 or '07 probably, so a good 15 years ago. For some reason, I remember it like it was yesterday. I also remember somehow stabbing my finger with a little pick tool as well during that install, lol.
Craig 85
Nashville, TN
454/TH-400/NP205
I have a Retro Sound Hermosa. I had to slightly file the sides of the OEM opening to get the outer sleeve to fit.
seanhatesregister
