Dodge Dana 60 up front
fowjacob
Lubbock,TX
c3500
383 Stroker
How much easier would it be to weld perches on the axle and use left springs then to do the cool setup?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
What?
The Dodge Dana 60 will bolt right in.
oopsman_09
Nampa, ID
Aaron
sierra classic c1500
i think he means coil spring to leaf spring
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Unit bearings, ball joints, and CAD make it a non worthwhile swap.
fowjacob
Lubbock,TX
c3500
383 Stroker
Yes Sorry my phone was change stuff I guess. Just wondering if i could weld perches on a axle that was a coil over set and if not how hard would be to use the coil set up on my crew cab?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Actually considered it at one point with my 90 R3500 crewcab when I had the Cummins donor truck sitting next to it.
fowjacob
Lubbock,TX
c3500
383 Stroker
considered puting perches on there or use the coil over set up?
Konas new ride
Alberta
Gerald
Would be a ton of fab work for a coil set up in a sb.. Its not just the coil you have to mount. its the four control arms and pan hard bar also. perches on a axle is easy..
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Was going to modify a long arm kit designed for the Dodge. 4 link with coils, just like would bree stock to the Dodge.
fowjacob
Lubbock,TX
c3500
383 Stroker
I would love to do the dodge 4link set up I just don't know if I have the experience, I'm very good at welding because the parents own a welding shop and I've been doing it for ever but idk if I really for suspension stuff. This guy did it http://youtu.be/bmOOZn6-S8U
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Just came across your other thread, if you've got the entire parts truck, go for it!
Btw, what is the distance from the outside if the frame to outside of the frame where the links mount to the rails?
fowjacob
Lubbock,TX
c3500
383 Stroker
I havent even had time to start measuring on the Frame or anything yet.
That's a wicked truck
Sent from my iPod touch 4th Gen using Tapatalk
gtewolf79
