- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
My cousin, who knows a fair bit mechanically but hes quite... good.. at thinking he knows EVERYTHING so its hard to determine, unless i already know, if he is talking out his ass, and his friend took a ride with me in my truck to the back of the property and when we got back were looking under the hood(they wanted to see) and made the comments that I need to do something about getting a valve job. I said why. They said burning oil smell.
This truck for about 10 years kinda puked a good amount of oil off the, well, any surface that oil can come out. Valve covers down. And I just fixed the valve cover gaskets this summer and retightened the one side which got loose(has since held tight?) and the engine of course is just covered in a thick veil of sludge of years of dirt, grease, oil, leaking fluid, power steering, water, you name it. As example, this is post-carburetor/valve cover, but pre retighten of valve covers (cleaned A LOT of the engine especially on top, around valve covers)
I did mention this to them, and they stuck to their guns insisting this engine is gonna grenade itself soon if I dont address it. I also pointed out to them that for 10 years gasoline was about 20% of the oil because of the shear amount of richness the carb it had before ran it. So the valve train is very clean... I never took a photo but that was spotless. Since october its had the same oil, which is dirty, yes, but not diluted with fuel anymore. I was gonna put in a nice quality oil here soon since it was probably the first oil change without excessive fuel dilution in a long time. Im also gonna do a tune up. I use a wix filter, if that means anything.
despite knowing i cleaned the top of the engine and fixed the leak, they say it has to be valve related because the amount of smoking on engine didnt correlate to the amount of smell. which i also told them that every bit of oil under the valve covers, so heads, exhaust, pan, etc. is all untouched and just as full of grime as before, and a lot of it happens to be near hot-things. They still insisted.
Do I have anything to worry about? Should I do or check anything?
Oil is still got some amber to it, not much.
Oil pressure is middle of gauge at warm running 20-30 psi at idle, iirc. I forget where the middle of gauge is. 0 to 50 psi gauge I believe?
