Diy4x shackle flip help
marks86
Latham, NY
Mark
12v Cummins
Truck has 56” springs, shackle flip is in the stock 1 ton shackle holes. I think I have the brackets on the wrong side. What do you all think.
keep in mind there is no weight on the springs at the moment.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
It looks like they're on the wrong sides.
marks86
Latham, NY
Mark
12v Cummins
I had a 50/50 chance :confused:
marks86
Latham, NY
Mark
12v Cummins
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
You see them both ways because they are reversible based on if you have 52 or 56 “ springs
Appears I am a dumb ass and you are correct. Next time maybe I will read you have 56" springs. Read they are supposed to flip sides for the 56" springs.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
So you should have done one facing forward and the other one facing back and THEN you would have 50/50 success ratio!
Once you get it happy and driving you will love it!
Swims350
Logan WV
none
I can understand the whole length thing but why do you see some where the shackle itself angles backwards and some forwards?
By that I mean the bottom is forward or back in relationship to the top of the shackle.
I would assume the axle is meant to go up and back not forwards.
SDJunkMan
Black Hills of South Dakota
Jeff
So has anyone out there made their own flip brackets? They don't look too complicated, just a few bucks in steel and a little welding. I definatly want to go with shackle flips vs blocks when I lift my shortbed.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
This kid did.
bglendon
