Bennyt
- May 17, 2019
- Surprise
- Ben
- C10
bending lines is teadious and a headache but in the end is pretty easy. the thought of 4 fronts seems unbalanced and overbuilt in my brain. i swapped the rears on my 70 camaro and the size difference was impressive but they were balanced. im guessing the large size locks up the back pretty easy?
Disc brake conversions on trucks are rarely a good idea in my opinion. If you never plan to tow/ haul; fine, but otherwise it's hard to find a caliper that matches the performance of a drum. I did do a rear conversion on my K5 that had a 14B FF in the rear. In that case, it was a primarily an offroad/ camping vehicle and did not need the giant 40lb 1-2T rated drum and a stock 12" rotor sufficed.
