Dieseling sometimes when hot
chevytech87
Tomball, TX
Brandon
GMC R1500
Hey all,
I’ve been driving my truck this week to break in the new motor and get a feel for the sniper EFI. Overall, been pretty happy with everything! I have noticed that sometimes, when the engine is at operating temp after a decent drive the truck “diesels” for a second or two. I’m thinking this may just be an idle screw/ IAC issue? First time I’ve tried to use this system and it’s a lot to take in. Any suggestions?
R Carnella
Long island
Rich
Suburban V2500
Leaking injector maby,combined with not enough octane?
pnwnvrdn
Grays Harbor County, Wa
Silverado K10
SBC
Pull/inspect spark plugs, they will let you know how efficient they are performing...I'm of the belief you will need to go to hotter, or colder plug, determined by what you find on your inspection of the old ones.
chevytech87
Tomball, TX
Brandon
GMC R1500
usual suspects
idle too fast, leaking injector, too hot, low octane fuel, vacuum leak, lean
CTS shows ~183, I am running 87 right now, so I suppose that could be an issue. How lean is too lean at idle? I think I’m sitting around 13-14:1. Idles at about 800
fast 99
Spokane, Washington
800 seems high unless it has a big cam requiring it. Automatic around 600 in gear is in the ballpark and 650 or so for manual. If there is an emissions sticker specs should be on it. Back in the day when we were having all sorts of drivability issues from low octane fuel, we adjusted the idle as slow as the customer could stand.
Automatics can be shut off in gear then put in park to minimize dieseling. If this problem continues an idle solenoid is an option. However, you need to do something NOW. Dieseling can very easily destroy a motor.
What octane fuel is in it?
That's a big spread. 13:1 is way richer than 14:1. If you are running 10% ethanol 87 octane, you should have a target AFR of 14.1-14.7:1. If you are running non-ethanol, you want target idle AFR to be 14.7:1. Cruise idle should be similar. Full throttle AFR should go into power enrichment and be ~12.5:1. Partial throttle AFR(but not high vacuum cruise) should be in the 13-14:1 range.
fast 99
Spokane, Washington
If air pump equipped AF ratio will be skewed.
He says its a new motor(I'm assuming a crate motor) and is running a sniper EFI. I'd be shocked to see someone put a sniper EFI on and then keep the stock SMOG equipment, BWTHDIK :shrug:
Also.. we need pics in this thread before Rusty comes up in here and throws a fit.
fast 99
Spokane, Washington
Agree, just tossing it out there. Some areas still smog check.
R Carnella
Long island
Rich
Suburban V2500
Put some 93 in there and i suspect the dieseling will stop.
chevytech87
Tomball, TX
Brandon
GMC R1500
@fast 99 I agree about 800 being high, I dropped it to 650 today and it’s seemingly much happier. The cam is substantial (Hydraulic roller 236/252' at .050" with 565" lift on 110'LSA) Had the idle set high for some reason I can’t remember when I was troubleshooting startup issues and never changed it. I am running pump 87, which I’ve been told I should stop doing. Will it run? Sure, but I’m guessing I’ll have more and more issues and I’m assuming it’ll spark knock at rpm once I break it in and can really get on it. So 93 it is from now on I guess. @Bextreme04 thanks for the info, I’ll have to check my tables and see what I’ve got desired set at. And suggestions for 93 AFR or are the numbers similar? For reference this is a freshly built 383 with some decent pistons and dart iron eagle 200 heads. Nothing too wild, but definitely not stock.
chevytech87
Tomball, TX
Brandon
GMC R1500
I promise i’ll take some tomorrow while I’m working on it! Haven’t taken any since I started driving it home again. It’s looking pretty sharp.
fast 99
Spokane, Washington
Those 2 items [RPM and octane] are likely enough to cause dieseling.
As much as it hurts, I use E free or high octane in the SB. Depending on the year today's high octane is actually lower than regular used to be. Everyday 30 cents a gallon regular was 94 or higher until they started to take the lead out.
2manysquares2care
