'Diesel rattle' in my 350...?
7900_Blazer
Francis
Blazer
Not sure how to describe the 'rattle' I'm hearing coming from, I believe, the front of the engine at idle - not a consistent rattle. The rattle does not 'come and go'... but also is not consistent - so not something like rubbing as the engine turns....
Again, a bit of backstory... bought the truck from a guy in Denver - have replaced a ton of stuff getting it road-worth... the seller communicated it had a solid engine... with a torque cam upgrade.
After many months off work, I'm finally where I can drive it and the engine definitely has a 'rattle' in the front at idle. Kind of reminds me of a diesel rattle at idle, or maybe a really really bad water pump type rattle but the water pump spins freely and feels solid.
The truck has good oil pressure - 60+ when cold... never gets below 30 even when hot and at idle.
Thoughts?
Captcorvette
Dubai
Capt
CK30
Does the truck have very old gasoline in it? Very low octane? When shutting the engine off does it die immediately or "diesel" a bit like it is trying to run then stop? Can you record the noise and send it in a file?
7900_Blazer
Francis
Blazer
Thanks for your help.
Truck probably had some 'old' gas... but I put 10 gallons or so of premium in it the first time I was able to drive it a few miles as a test (4 days or so ago).
No, it doesn't 'diesel' when shutting off the engine.
Yes, I can grab a video this evening and post the link here.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Fuel pump? Timing chain?? Is tgenoise constant, or will it come and go with engine speed? Take the belts off, is the noise still there? If so, it’s not a belt driven accessory.
Does the noise change shifting from park into gear? You said the noise appears to be coming from the front, a broken flywheel can make a funny rattling sound.
Rusty Nail
Rusty
350sbc
At idle...in gear? In park?
Does it change with engine rpm (ever) or no?
We're gonna need some pix of a 79 blazer pliz.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Yup, front accessories or timing chain.
Rusty Nail
Rusty
350sbc
Woah. What's the change between videos?
What belt? The water pump?
I thought "timing chain" at 0:04 and counted that sound 4 times before the first video ended. Faint at 07, 08, and 09. But that don't make no sense.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Seems like water pump to me. Could also be the alt, spin those over by hand.
350 w/203
Water pump.
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
If you haven't found it yet try putting a broom handle or a wood dowel against your ear then set the other end on the block in different places. CAREFULLY! It helps to narrow down the location.
78C10BigTen
pennsylvannia
C10 BIG TEN
Well what i see only leaves 2 choices.... water pump or alternator. Only 2 things not turning after belt was removed...
SirRobyn0
Rob
Yes you can also use a rubber hose, which will transmit the sound just fine, but won't get thrown at you if you hit something moving. Still need to be careful. Also I think it's likely to be the water pump as well.
Jawzjeep
Washington
Joshua
Suburban
Yeah your right. Over been beat by a rubber hose though? Either way its hurts to not be careful.
Bowtie72
