bluearmz
- May 9, 2015
- Staunton, va
- Richard
- GMC Sierra Classic 2500
Truck is 1987 GMC 2500 4WD / 14 bolt rear. Here's the issue. When taking off from a stop, and sometimes braking, especially downhill, I hear and feel a clunk/thump that sounds like it is coming from the passenger side rear end. It also happens when the rear wheel goes over speedbumps and low speeds. Also, if going down a rough road, where rear suspension is moving, you hear it as you hit little bumps.
It is not really a metal on metal clank... sort of a clunk/thump you can hear and feel too. Inspecting the rear, everything seems to be in order, and front end has got new ball joints and wheel bearings.
Is is maybe a rear shock? I tried that idea where you put leafspring clamps, cause sometimes movement will cause it, but no change. Also already took out and greased the driveshaft splines.
Any ideas?
Any ideas?
