Dano500
- Jul 4, 2023
- Houston, TX
- Dan
- K20
So, when I came across my truck, all tires were inflated, except front driver and who knows how long it was like this; several years. When I was working on it and testing different things, I’d take it around neighborhood and I could feel the bounce from what I thought was low point in tire. I just put on new wheels and tires. They look oddly balance to me with wheel weights, but they are the experts. The bounce was immediately gone. Felt nice at low speed, but when I tried it on feeder, say getting up to 55/60mph- then death wobble started, or bad balance of tires. That shaking of steering wheel side to side and whole cab going out of whack. I immediately slowed and it went away.
I got it home and checked for play. Tie rods are solid, but I did find problem with ball joint wiggle on passenger side, so now there is that. And, to make things more interesting, when I installed drop pitman arm, I also did drag link and I think I did it wrong- slightly toe out.
Second part of steering problem.
Steering wheel changes position with turning. Say I start off at 10 deg to right and with driving out of my place, I have to turn right and when I go back straight, wheel is like at 80 deg to right. When I turn left, it corrects it mostly. It feels like, or as if the splines on a 2wd steering box are worn, but I know 4wd gear boxes have the notch for the pitman arm bolt. Rag joint seems solid when I check it. Can anything in shaft behind firewall be the culprit?
Thanks in advance,
-Dan
Thanks in advance,
-Dan
