Dana 60 rear end gears
Michael Bellomy
Lamar Colorado
Michael
7.4L 454
I have a 86' GMC 1 ton dully. It has a DANA 60 with a 10 bolt cover. It currently has 4.56 rear end gears. I want to change them to something taller. Preferably 3.73's. what do i need to do?
Customblue
Locust Grove, Va
Brandon
A different size carrier or if they are availble in such a gear jump, gears to fit your series 4 carrier
Big Chip
Michigan
Kevin
C35
It's not a Dana 70HD?
nvrenuf
Mobile, Al.
It'll be a 70HD. (60 and 70 share the same cover)
@Michael Bellomy check the webbing on the housing, lower passenger side, rear face - it will have the axle model cast in it ("70HD"). Also, look at the axle tube size, it should be 4" and no D60 ever had that big of a tube.
4.56 is a the ratio break so you'll need a 4.10 and higher carrier to change to 3.73's. You will need to have someone set the gears up.
Loco Hills
K-30
Not saying you don’t have a 60,but is that the number cast on the lower right corner,next to the cover?
I would of thought a Dana 70 or 14 bolt.Anyhow,you will need a carrier for 4.10
nvrenuf
Mobile, Al.
IF it's a D60 rear axle it's been swapped in, GM never used a D60 in the rear of square body trucks.
thatguy76549
