cs 130 alt upgrade
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I put a cs130 on my truck today. I got the plug from orilys for $20. Had to alt already so im in it prety cheap my lights seem brighter seems to run better and when the fans kick on it doesnt drag the motor down as mutch. Everything seems to just wrk better. It was prety easy bolted right up pluged right in. Thanks for looking
MadOgre
NA
NA
NA
NA
NA
That's pretty cool what's the part# for that plug ?
I put a 110 amp on mine it was for a different application. Took the parts girl an hour to find it in her books with some cross referencing.
The only thing was I had to change the pulley and rotate the housing to the appropriate indexing. It was pretty simple just remove the 4 long skinny bolts that hold the housings together and rotate the 2 halves to the indexing that you need and then reinstall the bolts. Just don't pull the 2 halves apart or your gonna have fun getting it back together.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Here ya go
Thanks for sharing
350runner
tx
Ceasar
Nice upgrade. I went with the cs144 and also swapped the serpentine/v belt pullies of an 85 k10. Best electrical upgrade yet.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
The cs 130---144 whats the difference between them higher out put...higher output at idle??
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Also if you dont have a dash light you have to get the adapter with the little diode in it they do make two types it will have a black piece of heat shrink in the middle with a little 1/4 bump in it thats the diode. Or put a light bulb in line with it...not sure what it does but you need it
350runner
tx
Ceasar
With out a resistor the alternator will be short lived
350runner
tx
Ceasar
Can this thread be made a sticky?
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
So I put this alternator in my truck, its an alt that goes on a 1990 Cadillac Seville, 120 amps. Don't know whether its a CS130 or a CS144.
Bolted right up with minor mods to the brackets. I'm still waiting for my adaptor to come in the mail tomorrow. Hopefully it'll be a big improvement. Before my lights would dim every time I turned on the a/c, my wipers would slow down and after 2-3 minutes of continuous on-time, they would cut out. My power windows take forever to roll up and down etc. Sorry for the rant! Hope this cures everything, I'll know tomorrow.
350runner
tx
Ceasar
It looks like a cs130
MadOgre
NA
NA
NA
NA
NA
I don't know why they want to route the battery through their junction needlessly lengthening the route to the battery. That just seems stupid to me.
Obullard74
