Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
If the cruise transducer has speedo cables to remove it will require a cable for a non cruise truck.
The electronic cruise (no speedo cables) the vacuum hose and wiring harness are all in one bundle. It will have a power connector to the fuse box, a electrical connector to a brake switch h (along with a vacuum hose) a control module near the gas pedal, and a connector to the speed sensor.
