Crate engine swap advise please?
73 C10
California
Scott
You need a limiter that will limit the pull the vacuum can rod. The one you call a top limiter will keep you in an advanced state of some sort. Not good.
I don't think that's true. You set the limiter. Then you set base with no vac. So when used normally, when your vac drops (hit the limiter), you drop to base. Vac builds, and timing advances to whatever the stroke permits. It just takes more vac to get it started.
350runner
tx
Ceasar
Oh grasshopper... Listen this whole top and bottom thing is going askew. The only sort of limit apparatus you need is one that limits the pull of the can rod into the can. This will give you the same effect you are talking about. Is that the kind you currently have installed?
73 C10
California
Scott
So you have the top limiter correct?
I have the Crane type in the link.
I don't no if it's more common, but it's definitely easier to find, and refered to more when searching the net.
350runner
tx
Ceasar
Ok, that will limit the amount of timing provided. That's fine if you use it to limit the amount of rod stroke back into the can.
73 C10
California
Scott
Yeah it will limit, but I think it would be best if the pull pin could remain in the same start position, and pull the pin into the limiter.
I may try installing it on the other mounting screw on the other end of the stroke and see if it will interfer correctly there.
I have it installed how Crane suggests.
73 C10
California
Scott
Also, because of useing a limiter I think some diaphragm spring adjustment is nececary.
And the adjustment makes more sense if the limiter were limiting the top of the stroke.
350runner
tx
Ceasar
You have the wrong limiter and it is causing your ignition too stay in an advanced state. Please read that thread in the link that I posted.
350runner
tx
Ceasar
Here is an awesome guys email. His name is Dave Ray. He builds small body hei distributors. He has this crane limiter down packed in an email he will send the directions on " how to" use the crane limiter correctly. All you have to do is ask it's free instructions and while your there ask him anything else you have questions about.
[email protected]
73 C10
California
Scott
If you have to drop more vac with out the limiter, I would think you would have a better chance of staying in an advanced state.
A lot of vacuum hose volume probably wouldn't help this.
I wouldn't expect to see vac drop to 5". I don't think it does on my gauge in the cab. Therefore it would still be in an advanced state.
This seams to to be normal stock.
With the Crane in the bottom, limiting to 15*, vac only needs to drop to 10" to get to base timing. More likely I think.
73 C10
California
Scott
[email protected]
Yeah. I just read an artical by this guy. Thanks. I seams like he agrees.
Post #9
http://www.chevelles.com/forums/showthread.php?t=390643
350runner
tx
Ceasar
When the vac can rod retracts into the can it is advancing the timing. With the limiter acting as a stop on the side crane is suggesting the timing will always stay in an advanced state with or without the vacuum can connected to a vacuum source. It just the nature of the beast. When you lose vacuum your losing the amount of advance the distributor is seeing which is how it's designed.
rich weyand
Bloomington Indiana
Rich
This is very important to get correct. Play with it with your vacuum pump and gauge until you get it correct. If you are holding VA in all the time, you will never be able to tune the engine properly.
Remember the spec for the stock AR23 can: 5-7 7.5 @ 11-12.5
- starts pulling in between 5" and 7" vacuum.
- 7.5 camshaft degrees (15 crankshaft degrees) total, all in.
- all in by 11" to 12.5" of vacuum.
(Or for $20 you could just buy a stock AR23 (VC1853) can and not worry about all the adjustment, limiters, etc. http://www.napaonline.com/Catalog/C...cuum-Advance-Control/_/R-ECHVC1853_0168354142)
350runner
tx
Ceasar
Another note... I find small blocks like the vacuum advance to pull down to 5" of vacuum(the least amount a performance can will pull to). I feel it is because this is when the engine has the most load on it before the trans down shifts and removes some of the load on the engine and puts the cam higher in its power range. While driving before the down shift is where the engine could use the extra timing from the vac can the most as the rich A/f ratio is at its richest state and will tolerate the the total plus vacuum advance you have your dizzy set for.
Ninao
