vkh
- May 21, 2015
- Western Montana
- Var
- C2500
So in an episode of engine masters they tested some common mechanical cooling fans to see how much horsepower they actually use. They had a mild 350 that made 349 hp and 406.9 ftlb. They were winding it out to around 5500 rpm. They had a radiator and shroud, all the fans were the same diameter and had 6 blades.
The thermal clutch fan ate 14 hp and 6.9 ftlb.
The plastic flex fan ate 23.9 hp and 18.6 ftlb.
The aluminum fixed fan (shallow blade angles) ate 20.3 hp and 12 ftlb.
The old school steel fixed fan ate 30.4 hp and 18.6 ftlb.
Without shroud the steel fan ate 22.3 hp and 17.9 ftlb.
These were the largest point differences but seeing the graphs but it does follow a steady trend. Worth noting too that the dyno room was quite cool, I think it's safe to say the thermo fan would eat more power on an average summer day.
So I was quite surprised by how much power mechanical fans eat, I was always a little skeptical about how much benefit electric fans bring but now I'm convinced.
For a power estimate for an electric fan a 30 amp fan uses about 360 Watts at 12 volts. Giving the alternator a 75% efficiency it would use 480 Watts mechanical, which is .64 horsepower.
Thought you guys might find it interesting.
