Control Arm question
DaleC10
wichita, KS
clint
C10 swb
5.3 vortech
Hey everyone, I bought these control arms for my c10. I will post the link below. I am new to this stuff and to this forum and i’ve got a question about greasing the bushings.
These control arms did not come with grease zerk holes. I am wondering if I can pull the bolts from the ends to apply grease after I have already installed them. Most control arm sets I have seen (after purchasing these) come with a zerk fitting hole. I installed these and they have a terrible creak leading me to believe they did not come greased. It’s not a light creak/squeak it Is something you cannot drive around without complete embarrassment. Any help would be appreciated.
bluex
Spartanburg SC
C15
What arms did you buy, you left off the link. It depends on what the bushings are made of on of they are greasable or not.
DaleC10
wichita, KS
clint
C10 swb
5.3 vortech
Bluex, whoopsHere’s the link.
Says they can be greased. I took out the bolts from the shafts and coated the bolt with some grease. It didn’t work so I’m wondering if I should have just stuck a grease gun in the hole and filled it, then pushed the bolts in and tightened them down.
bluex
Spartanburg SC
C15
You'll probably have to take them back off an remove the bushings to grease them. It's also possible it's only squeaking on the side between the bushings an the chassis mount. Either way you'll have to take them lose to do it right.
DaleC10
wichita, KS
clint
C10 swb
5.3 vortech
Do you think the bushings are pressed in? It say Del-a-Lum style.
idahovette
Weiser Idaho
Perry
K20-K10
Take some pic and post what YOU have........bushing ends and complete a-arms
bluex
Spartanburg SC
C15
I don't know about those specific arms but those are generally not a super tight fit. They should come out without needing a press.
Pretty sure your noise is coming from between the bushing an the chassis mount though. Try spraying something there to see if it goes away before disassembling
DaleC10
wichita, KS
clint
C10 swb
5.3 vortech
I got it fixed! I took apart everything and got the bushings out. They felt like plastic bushings but I put grease in all over in all 4 an arms and not it’s not creaking at all. Thanks man!
99tan99
