GXPWeasel
- Nov 5, 2019
- Kansas
- Greg
- 1982 | 2015
- Sierra C15 | Silverado Z71
- 5.0 | 5.3
One of those wires is the power coming up from the starter lug and should have a fusible link at the starter side. The other wire is the ignition power going into the cab and should have a fusible link at the power block. Get rid of the wire nut and connect them to the lug with correct heat shrunk connectors and the fusible link so they don't corrode or come loose in the future.
Yes, I will definitely fix it correctly. This was a temp solution to make sure I had everything connected to the correct wires to start with. The wire coming from the starter does in fact have the fusable link in it as it should. The wire coming down from the block on the firewall s/b connected to the wire coming from the starter. It was cut where I have the wire nut. The 3rd wire under the wire nut is going into the bulkhead connector, bringing power to the ignition switch, among other things. There is still a cut wire if you look closely, at the power block, which is where I believe that wire going back through the bulkhead connector should be connected to. Thus that power block replacing my wire nut. I may need to add some wire to the wire going through the bulhead connector though, as I think it's a bit short. If so, I'll make the splice closer to the bulkhead connector.
