Weasel74
- Apr 4, 2023
- North Carolina
- Jon
- Chevy Cheyenne C-10
I have a ‘74 Cheyenne with a 350, th350, rebuilt Q-jet carb & new gas filter, new gas tank, sender, and hose lines, new fuel pump, new coil, plugs, points, rotor and condenser. The engine may crank for a few seconds and die off. The dwell is correct and the timing was not moved when it was running. I have set the idle mixture screws at 2 turns out. I have checked plug wire sequence and all vacuum lines are connected.
Any suggestions or help is greatly appreciated! Weasel74
