Complete Interior Install
86c10twotone
MD
Roy
Looks fantastic!
Rick76
Pittsburgh, PA
Mine didn’t fit. Still not screwed in on driver side.
You talking LMC $400ish metal-backed dashes? I used a preexisting hole in the truck's metal sub-dash (I think PO drilled it) to run a screw from the inside out into the backing of my LMC dash as I held it in place. That held enough to get it draped and molded perfectly around the instrument bezel and sitting firm with the sub-dash. I figure it will settle down once it gets some heat even if the screw lets go at some point.
Richmond, VA
Andrew
I will give it another shot
billbill321
