Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
Yeah, you guys are right on all counts. My original radiator size is 27 1/2" X 19" and this new one is the same size. And there was the suggestion I get a larger radiator to get the cores I had in my old radiator, which the new one has. But I would have to change my whole radiator support and I wouldn't be able to shut the hood. And the framing of the support I have won't allow me to get any different size radiator, which is fine with me I can work with what I've got.
I run a Robert Shaw 180 degree therm. The Shaw therm. if some of you aren't familiar with it, has nearly a 1" opening in it when it's fully open instead of the tiny opening Stant therm's have. It's designed for performance engines so that the max coolant gets to engines that run somewhat warmer than stock engines. And the Shaw is made to open precisely at the setting due to much better quality metals it's made from. I've never used a Stant in my engine.
I guess what the deal is I'm used to how that old stock radiator reacts to certain conditions and this all aluminum radiator reacts differently as it should. Reaction time of how the metals react to temp. changes show up on the temp. gauge differently than I was used to and I'm thinking that like "Grit dog" said, that there was something wrong with the gauge, that after twenty-five years that it was worn out or something. I even called Auto Meter and talked to them about if I could send it to them and have them check it and if something was wrong with it they could fix it. I did find out that they do repair their gauges.
So it's all cool. It's just this radiator reacts differently to temp. than what I was used to and it was making me think there was something wrong.
Hey, I'm puttin in a "Air/Oil Seperater" today. I don't know how long these things have been available, but I needed one for a long time. It's not that I have a oil problem but when I changed my intake gaskets recently I noticed how filthy the intake runners were with oil from that dang PVC valve blowing oil back into the engine so it will reburn "oil contaminates", stupid environmentalists. When I came back from Viet Nam I had saved most of my paychecks and went to my local
Ford dealership and paid cash for a new '69 Mustang 351 with a three speed stick, Red with a burgundy interior. I would have bought a fastback but the insurance was twice what it was on the one I got. The one I got was what was called a "Sport Back". You know how the '60's Chevelles had those wings on each side behind the rear window? Well, this model I got had them but about half that size. The 1969 Mustang was the coolest body style Ford ever had for that car.
