Clearance Light Location
GregL
Palm Springs, CA.
Greg
K 20
I'm going to install a set of roof lights on my '77 K20. So I'm looking for someone that has the original GM installed clearance lights on their cab. I'd like to get the location measurements.
Thanks!
Hawkeye283
Indy
Tom
I'm wanting to do the same thing on my 75 K20. Need the measurements, but the link can not be found. Could someone reload it or let me know what I'm doing wrong? I've tried opening it up in a different window-that didn't work. Many thanks!
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I'm not sure what link I posted before but I did some digging and found this thread:
and looking around in there I found a written explanation that was posted on another site:
As your looking at the roof from the front bumper let's number the lights 1 - 5, passengers side to drivers side.
1. Diameter of all the holes is 1 3/8"
2. Center 3 holes (#'s 2,3 & 4) are located 5 3/16" back from the edge of windshield gasket to center of hole. Front leading edge of 3 center holes is 4 1/2" from edge of windshield gasket.
3. Center 3 holes measure 6 3/8" center to center to center. 12 3/4" center to center from hole 2 to hole 4.
4. Holes 1 & 5 (outer most 2 holes) are located 5 3/16" from the inside edge of the drip rail to the center of the hole with the edge of hole measuring @ 4 1/2" from the inside edge of the drip rail.
5. Holes 1 & 5 measure 6 3/16" from the edge of the windshield gasket to the center of the holes with the edge of the holes measuring @ 5" from gasket edge.
6. Holes 1 & 2 measure center to center 17 3/8" with 16" from edge of hole to edge of hole.
Holes 4 & 5 measure the same as 1 & 2.
7 Screw mounting holes are 2 3/4" across the center of the larger holes.
8. Outer 2 lights are angled outwards about 10 to 15 degrees from straight forward.
Hawkeye283
Indy
Tom
Perfect! Just what i needed. Many thanks! Tom
Craig 85
Nashville, TN
454/TH-400/NP205
I have these photos. Don't know if you can blow it up large enough to see the numbers clearly. FYI the OEM outer lights are supposed to be at about a 45 degree angle.
GorillaHumper
