- Feb 15, 2022
- North Central Washington
- Dave
- Scottsdale
I do follow your posts being that your are a mechanic, square enthusiast and a neighbor more or less lol. I am real hesitant to pull the emission garbage but my mechanic is insistent it needs to go. I just replaced both tanks, senders, all the rubber lines and cleaned up my grounds. The damn thing starts first whack every time now! It runs a little rough while cold but there a a couple missing vacuum lines from the EGR (which is bypassed) and air valve/pump. I think if the EGR was replaced and those missing lines restored it would be good as new and probably slightly better MPG's than a 350, which right now is welcomed. The weird thing is that now when I turn the key to start it it'll click(rattle) for a bit. I think when I put everything back I hooked up something that was previously disconnected, maybe a valve or heater circuit or something?I'm right there with you. IDK, if you have seen my threads on it, but I just went though an oil control issue. Long story short my plan always has been to run the 305 until it's done and then swap in something else, most likely a 350. I was ready to pull the trigger, and order a 350 but my engine builder had a 3 month wait. So I ended up doing valve stem seals and an intake gasket to help the 305 out. At the time I was figuring I'd order the 350 in the fall and install it in the winter when the farm is less dependent on the truck. The only trouble is the 305 is now running so darn good. I guess we'll see how I feel come this fall, but I might decide to keep running the 305 for a while. I mean it's still getting the job done!
