Circle D giving me problems
85kayten
Stephen
I need some diagnostic help.
When I am in D everything shifts and powers normal. Once I shift into Circle D I can drive it ok, but if I get on the gas she just wont go. Also at lower speeds around 50mph or lower she starts trying to change gears, but it just doesn't happen, so it feels like I'm going to stall or just something bad is happening in there. I have to downshift back into D and then things are ok again.
Any insight, guesses, or snide comments? Thanks
DanMcG
Central NY
k10 k10
I can't help you much here, but circle D is overdrive (OD).
85kayten
Stephen
Yep OD. Thanks anyway.
If I had to guess, it's a 305 with tall gearing and the trans likes to shift into OD too early. Making sure the TV cable (like a kickdown cable) for the trans is adjusted properly would be a good place to start.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Totally thought this thread was going to be about torque converter issues...
yevgenievich
Place
Name
Year
Model
Size
Maybe this is one of those cases where lockup was wired directly to 4th gear switch.
Norm310
