chevyninja350
- Mar 27, 2021
- Illinois Near St. Louis area.
- Andrew
- C10
I need help.
I know stock Chevy 350s are happy with 650 CFM carburetors. That being said I have a 750 Edelbrock 1411 on my non bored over 350 9.93:1 compression that is far from stock.
It has an Edelbrock dual-plane intake, A lopey 510/520 lift cam (2200-5800 RPM) and aftermarket vortec heads that I have ported and Polished myself.
Whenever I tell people I have a 750 CFM on a 350 they freak out saying my carburetor is too big but to me it doesn't feel like it's too big. When I stomp on the gas it does not bog it just goes, when I read my spark plugs either after daily driving it for a while or driving it hard the spark plugs look clean with light amount of soot around the ring at the end of the threads (in other words they look fine to me) and the vehicle idles fine. If this will tell you anything I have a vacuum reading between 15 and 16 inHg. I have not changed Jets metering rods or Springs.
When I tell people (including shop owners) that the engine runs fine. they say oh well it's still too big you're probably losing to tuneability or losing power at higher rpms.
So what I'm asking is is my carburetor too big, if not what defense can I use to make these people stop freaking out and what are the signs that a carburetor is too big?
1985 chevy c10 262 v6 swapped to around 400hp 350 vortec heads
Stage 3 700r4
Stage 3 700r4
