Carbs at local auction
CSFJ
The one on the far right is a q-jet, the rest I would guess Chrysler origins for. None of those 3 look familiar to me. I would think the q-jet would be worth 30 or so, they seem to sell for more than that on c-list for core condition,.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Look like Carters. Except for the Q-Jet
Camar068
10 yrs Air Force
they worth more than $50? Thought is to flip them.....lol I don't need them.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The one on the left kinda looks like a Carter Thermoquad, but it's hard for me to see them. Quadrajet's a way better carburetor in my opinion, which there's one in the lot, but those would probably be worth something to someone doing a proper resto or repair in the Mopar world.
Camar068
10 yrs Air Force
All said and done I got em for $50. May keep the qjet depending on what the others are.
Thanks Everyone for the help/info.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Oh come on what's wrong with a thermo plastic carb nothing can go wrong there......
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
No, of course not. Glass fuel filters and plastic carbs are what all the cool kids are running.
:flamingdevil:
Yep, those are Chrysler Carbs. Carter AFB and AVS on the 2 center ones IIRC and then the Q Jet. I'm pretty sure the center 2 are not Thermoquads by the shape, but the pics aren't good enough for a positive ID. The 1st is an AFB though which is what the Eddy Carb is derived from.
Camar068
10 yrs Air Force
Thanks Guys, will post makes/models when I get em Monday.....pics as needed.
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Center ones look like 4 jets, the predecessor to the Quadrajet. Legit appears to be old Carter AFB, same as the current Edelbrock.
You can get your money back out of them plus some.
AFB will have code stamp on front left of base. 4 jets should have a tag but most were lost.
I'd agree with those center being 4 jets. I wasn't sure what they were called, but after I made that post and got to looking at some of my old Carb pics. They were carbs if you went to Pep Boys for example for a Qjet replacement, you could have ended up with one of these.
Camar068
10 yrs Air Force
Right....
- 2 each 4 jet (1= 59 - 64 oldsmobile, not sure of other yet)
- 1 quad
- 1 Carter 3921s (65-66 buick)
Thanks for the help
Camar068
10 yrs Air Force
Trim from maybe an eldorado came with them.
If you pull the numbers off the Quadrajet you can look it up and find out what "vintage" carb you have.
Unless you need to match an older engine for restoration, the newer quads (about mid 70's and on) are usually less likely to leak, and the next generation (late 70's to mid 80's) have some additional adjustments that can make them a little easier to tune (like external access to the the adjustable part throttle (APT) setting).
There were also a few electronically controlled Quads, but I think the electric solenoid was emissions related and didn't really do that much for tuning.
seanhatesregister
