Carb Adapter
I have used many of these to put a Holley/Edelbrock on a spread bore performer intake on my big block Dodge motors. Some say they are better on aluminum intakes but for what they cost it may be worth a try. A 1/2 phenolic or wood spacer on top of it may help with fuel percolation.
Those will only work on an aftermarket intake with a divided plenum. You can also stack 2 or 3 of them, with a gasket between each, to act as a heat insulator.
Here's what I'm talking about with the 4-hole style adapter. As the primaries open up, one half of the butterfly basically feeds air straight into an aluminum wall. Once you hit around 75% throttle, it doesn't look to be too much of a restriction. But in the area where a vehicle is regularly driven (by the average person), that adapter really gets in the way of the airflow on one side of the butterfly. Maybe in the real world, it doesn't actually hurt anything on a stock engine. I don't know, I've never used the 4-hole type before.
Sad Sack
Omaha, NE
Goober
C15
If you have deep pockets, spend the $$$ get the Holley spread bore replacement. They are pricey but direct bolt-ons. Your year would have used the List 6210 model, you'd have to research current offerings.
Current offering:​
Holley 4175 650 CFM 4-Barrel Carburetor 0-80555S
Mlcdc1
IN
Thanks - interesting conversation/info
ali_c20
Austria
Alexander
C20, K5
The AVS 2 is spread bore but advertised as square bore. The difference in bore is not as big as on the Quadrajets but I bolted mine directly to the sread bore manifold of my K5 with a 1/4" gasket.
https://www.summitracing.com/parts/edl-1906
Mlcdc1
IN
Interesting - any issues with getting it tuned/dialed in?
Gave up on tuning the quadrajet and bought an Edelbrock 1906 for my 1977 C15 with 350 engine. Looks like there are a couple of options available for the adapter to fit it to my stock spreadbore intake. Any recommendations or opinions?
I totally missed the 1906 part just saw Edelbrock and adapter and stated my opinion Good catch by @ali_c20 1906 will bolt to spreadbore no adapter required. Whenever I see Edelbrock and carbureator I always think of the standard performer carb.
Turbo4whl
Downingtown, PA
Wayne
Double pumper, mechanical secondaries. Plenty of go but poorer fuel economy. Better choice is a Holley 9895. Vacuum secondaries, an electric choke. Very tune-able, and still available new. The 6210 and 9895 are both, 650 CFM. New they are a lot of money now. You can find them at swap meets as Holley built and sold lots of these direct fit carbs.
ali_c20
Austria
Alexander
C20, K5
Nope, bought the tuning kit with springs, needles and jets. First put in the springs matching the engine vacuum and from that jet and needles.
I run the 500cfm version on my 350, throttle response is great, like a monkey on speed.
Before you tune your carb make sure your ignition is set right and check your spark plugs and wires if they need to be replaced.
How far off is the transition to the manifold? Was the 1/4" gasket needed for butterfly clearance?
ali_c20
Austria
Alexander
C20, K5
The bore of the stock manifold is 1.375 and the AVS2 has 1.44 but of the bore positions don't match.
On the stock manifold with 4 holes you need the adapter.
I use the thick gasket for some heat insulation.
On Edelbrock spread bore manifolds there are no clearance issues.
ali_c20
Austria
Alexander
C20, K5
Sorry for double posting.
The bore of the stock manifold is 1.375 and the AVS2 has 1.44.
I use the thick gasket for clearance and some heat insulation.
Ok, so you used an aftermarket manifold with a split plenum? As opposed to a factory intake with 4 holes?
ali_c20
Austria
Alexander
C20, K5
Yes.
I edited my first posts, I forgot that I have an aftermarket manifold... early morning in Austria.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
So the AVS2 or 9895 would be a direct swap onto both the alloy oem spreadbore intake on my 70s 350 -AND- the high rise oem iron intake for my 85’s 4.3L V6? Asking because the Qjet I have needs to be rebuild and will not come apart. Could only get the lower plate off for a gasket replacement. Top 2/3 are stuck solid.
zacharyb
